Skip to content
Customize design
You can customize the design of the mailcow UI and of SOGo:
What mailcow UI SOGo
Colors and fonts Theme Theme
Single elements CSS overrides –
Logo Logo and texts Logo
Title, texts and footer Logo and texts –
Favicon Favicon Favicon
mailcow UI
Themes
Since mailcow 2026-10, themes change the look of the mailcow UI: colors, fonts and other styles, in light and dark mode. mailcow ships the theme servercow.
Select a theme
Navigate to System > Configuration > Options > Customize, choose a theme in the section Theme and click Save changes. Default is the standard look of mailcow.
Below the selection, all installed themes are listed with their folder name. A moon icon marks themes with a dark mode variant. The theme applies to all users and to the login page.
Create your own theme
A theme is a folder data/web/css/themes/<name>/. The name may contain letters, digits, - and _.
File Required Purpose
theme.css yes Loaded after the CSS of mailcow
dark.css no Loaded in dark mode, after the dark mode of mailcow
bootstrap.css no Replaces the Bootstrap base theme (Lumen), e.g. with a Bootswatch theme for Bootstrap 5.3
theme.json no Name and description in the list of themes
theme.json
  "name": "Example Corp",
  "description": "Colors of Example Corp"
The easiest way to style mailcow is to change its CSS variables in theme.css:
theme.css
:root {
  --mc-primary: #2d6a4f;
  --mc-primary-border: #245a42;
  --mc-body-bg: #f6f8f7;
  --mc-font-family: Arial, sans-serif;
All variables and their defaults are found in data/web/css/build/014-mailcow.css (light mode) and data/web/css/themes/mailcow-darkmode.css (dark mode). Change the variables of the dark mode in dark.css. The theme servercow in data/web/css/themes/servercow/ is a complete example including fonts.
Tip
  • mailcow bundles the CSS files and detects changes automatically, reloading the page is enough.
  • Put fonts and images into the theme folder and reference them with absolute paths, e.g. url('/css/themes/<name>/fonts/font.woff2'). Browsers cache these files for a long time, so give a changed file a new name.
  • Your own theme folders are not tracked by git and persist over updates. Updates overwrite the theme servercow. To change it, copy it to a new folder first.
Default theme
$UI_THEME in data/web/inc/vars.local.inc.php sets the theme that is used for Default. A theme selected in the mailcow UI takes precedence.
<?php
$UI_THEME = "examplecorp";
As in earlier versions, $UI_THEME can also name a single Bootswatch file data/web/css/themes/<name>-bootstrap.css.
CSS overrides
For a few small changes, a theme is not necessary. Put your CSS into data/web/css/build/0081-custom-mailcow.css. The file is excluded from tracking and persists over updates.
Logo and texts
In System > Configuration > Options > Customize, administrators can also change:
  • Change logo: The logo of the navigation bar and the login page, optionally an inverted variant for dark mode. A scalable graphic (SVG) is recommended.
  • UI labels and texts: The website title, the names of the mailcow UI and the apps, the help text below the login mask, announcements and the footer.
  • App links: Additional links in the apps menu.
SOGo
SOGo theme
mailcow builds after 28 January 2021 can change SOGo's theme by editing data/conf/sogo/custom-theme.js. Please check the AngularJS Material intro and documentation as well as the material style guideline to learn how this works.
You can use the provided custom-theme.js as an example starting point by removing the comments. After you modified data/conf/sogo/custom-theme.js and made changes to your new SOGo theme you need to
1. edit data/conf/sogo/sogo.conf and append/set SOGoUIxDebugEnabled = YES;
2. restart SOGo and Memcached containers by executing the command:
docker compose restart memcached-mailcow sogo-mailcow
docker-compose restart memcached-mailcow sogo-mailcow
3. open SOGo in browser
4. open browser developer console, usually shortcut is F12
5. only if you use Firefox: write by hands in dev console allow pasting and press enter
6. paste java script snippet in dev console:
copy([].slice.call(document.styleSheets)
  .map(e => e.ownerNode)
  .filter(e => e.hasAttribute('md-theme-style'))
  .map(e => e.textContent)
  .join('\n')
7. open text editor and paste data from clipboard (Ctrl+V), you should get minified CSS, save it
8. copy CSS file to mailcow server data/conf/sogo/custom-theme.css
9. edit data/conf/sogo/sogo.conf and set SOGoUIxDebugEnabled = NO;
10. append/create docker-compose.override.yml with:
services:
  sogo-mailcow:
    volumes:
      - ./data/conf/sogo/custom-theme.css:/usr/local/lib/GNUstep/SOGo/WebServerResources/css/theme-default.css:z
11. Run:
docker compose up -d
docker-compose up -d
12. Run:
Reset to the default theme
1. checkout data/conf/sogo/custom-theme.js by executing git fetch ; git checkout origin/master data/conf/sogo/custom-theme.js data/conf/sogo/custom-theme.js
2. find in data/conf/sogo/custom-theme.js:
// Apply new palettes to the default theme, remap some of the hues
    $mdThemingProvider.theme('default')
      .primaryPalette('green-cow', {
        'default': '400',  // background color of top toolbars
        'hue-1': '400',
        'hue-2': '600',    // background color of sidebar toolbar
        'hue-3': 'A700'
      .accentPalette('green', {
        'default': '600',  // background color of fab buttons and login screen
        'hue-1': '300',    // background color of center list toolbar
        'hue-2': '300',    // highlight color for selected mail and current day calendar
        'hue-3': 'A700'
      .backgroundPalette('frost-grey');
and replace it with:
    $mdThemingProvider.theme('default');
3. remove from docker-compose.override.yml volume mount in sogo-mailcow:
4. Run:
5. Run:
mailcow builds after 21 December 2018 can change SOGo's logo by replacing the following files:
data/conf/sogo/custom-fulllogo.png
data/conf/sogo/custom-fulllogo.svg
data/conf/sogo/custom-shortlogo.svg
After you replaced said file you need to restart SOGo and Memcached containers by executing:
Favicon
mailcow builds after 31 January 2021 can change SOGo's favicon by replacing data/conf/sogo/custom-favicon.ico for SOGo and data/web/favicon.png for mailcow UI. Note: You can use .png favicons for SOGo by renaming them to custom-favicon.ico. For both SOGo and mailcow UI favicons you need use one of the standard dimensions: 16x16, 32x32, 64x64, 128x128 and 256x256. After you replaced said file you need to restart SOGo and Memcached containers by executing:
