Skip to content
mailcow Logs Viewer
A modern, self-hosted dashboard for viewing and analyzing mailcow mail server logs. Built for system administrators and technicians who need quick access to mail delivery status, spam analysis, and authentication failures.
Features
  • Dashboard: Real-time statistics, container status, and storage usage.
  • Messages: Unified view of Postfix and Rspamd data with smart correlation.
  • Security: Netfilter logs visualization for failed authentication attempts.
  • Domains: SPF, DKIM, and DMARC validation and monitoring.
  • Mailbox Statistics: Per-mailbox insights on usage and traffic.
Installation
You can easily run the logs viewer using Docker Compose.
  1. Create a directory and enter it:
    mkdir mailcow-logs-viewer && cd mailcow-logs-viewer
  2. Download the docker-compose.yml and env.example files from the repository.
  3. Configure your .env file with your mailcow URL and API key.
  4. Start the container:
docker compose up -d
docker-compose up -d
  1. Access the dashboard at http://your-server-ip:8080.
For full installation instructions and configuration options, please visit the Getting Started Guide or the GitHub Repository.
