Traefik v3 (community supported)
Important
First read the overview.
Danger
This is an community supported contribution. Feel free to provide fixes.
This tutorial explains how to set up mailcow with Traefik as a reverse proxy to handle HTTPS connections, domain routing, and certificate management.
Prerequisites¶
- Traefik v3.x installed and running
- Domain names configured to point to your server according to this guide
Overview¶
Traefik will handle all incoming web traffic and route appropriate requests to mailcow. This setup allows Traefik to:
- Manage SSL certificates
- Handle autodiscover and autoconfig services
- Handle frontend UI
- Pass ACME challenge responses for certificate validation of the mail server
Update mailcow Configuration¶
First, modify your mailcow.conf or .env file to disable mailcow's built-in SSL handling:
# Disable mailcow autodiscover SAN
AUTODISCOVER_SAN=n
# Skip running ACME (acme-mailcow, Let's Encrypt certs) - y/n
SKIP_LETS_ENCRYPT=y
Configure Traefik¶
Create or update your Traefik dynamic configuration file with the following content:
http:
routers:
mailcow:
entryPoints: "websecure"
rule: "Host(`mail.domain.com`)"
service: mailcow-svc
tls:
certResolver: cloudflare
mailcow-autoconfig:
rule: "(Host(`autoconfig.domain.com`) && Path(`/mail/config-v1.1.xml`))"
tls:
mailcow-autodiscover:
rule: "(Host(`autodiscover.domain.com`) && Path(`/autodiscover/autodiscover.xml`))"
tls:
services:
mailcow-svc:
loadBalancer:
servers:
- url: "http://mailcow-nginx-mailcow-1:8080"
Add / Update your docker-compose.yaml file:
services:
certdumper:
image: ghcr.io/kereis/traefik-certs-dumper:latest
container_name: traefik_certdumper
restart: unless-stopped
network_mode: none
command: --restart-containers mailcow_postfix-mailcow_1,mailcow_dovecot-mailcow_1
volumes:
- traefik_certs:/traefik:ro # mount your traefik certificate file
- ./data/assets/ssl:/output:rw
environment:
- DOMAIN=domain.com
- ACME_FILE_PATH=/traefik/cloudflare-acme.json # your traefik acme file
nginx:
expose:
- 8080
labels:
- traefik.enable=true
- traefik.http.routers.mailcow-autodiscover.entrypoints=websecure
- traefik.http.routers.mailcow-autodiscover.rule=Host(`autodiscover.domain.com`) && Path(`/autodiscover/autodiscover.xml`)
- traefik.http.routers.mailcow-autodiscover.tls.certresolver=cloudflare
- traefik.http.routers.mailcow-autodiscover.service=mailcow-svc
- traefik.http.routers.mailcow-autoconfig.entrypoints=websecure
- traefik.http.routers.mailcow-autoconfig.rule=Host(`autoconfig.domain.com`)&& Path(`/mail/config-v1.1.xml`)
- traefik.http.routers.mailcow-autoconfig.tls.certresolver=cloudflare
- traefik.http.routers.mailcow-autoconfig.service=mailcow-svc
- traefik.http.routers.mailcow.entrypoints=websecure
- traefik.http.routers.mailcow.rule=Host(`mail.domain.com`)
- traefik.http.routers.mailcow.tls=true
- traefik.http.routers.mailcow.tls.certresolver=cloudflare
- traefik.http.routers.mailcow.service=mailcow-svc
- traefik.http.services.mailcow-svc.loadbalancer.server.port=8080
- traefik.docker.network=proxy
restart: always
networks:
mailcow-network:
aliases:
- nginx
proxy:
Important notes about this configuration:
- Replace
mail.domain.com,autoconfig.domain.com, andautodiscover.domain.comwith your actual domain names entryPoints: "websecure"- replace it with your actual Traefik https entrypointcertResolver: cloudflare- replace it with your actual certificate resolver
Step 3: Restart Services¶
Restart both Traefik and mailcow to apply the changes:
# Restart mailcow
cd /path/to/mailcow-dockerized
docker compose up -d
# Restart mailcow
docker-compose up -d
Testing Your Configuration¶
- Visit
https://mail.domain.comto check if the mailcow web interface loads properly - Configure an email client to test autodiscover functionality
- Monitor Traefik logs for any routing or certificate errors
Troubleshooting¶
Certificate Issues¶
- Check
traefik_certsdumperfor any errors / missing acme file - Ensure the Certificate file is correctly mounted
Routing Problems¶
- Verify network connectivity between Traefik and mailcow
- Check that the mailcow IP address is correct in Traefik configuration
- Make sure all required ports are open in firewalls
