Traefik v2 (community supported)
Important
First read the overview.
Danger
This is an community supported contribution. Feel free to provide fixes.
This tutorial explains how to set up mailcow with Traefik as a reverse proxy to handle HTTPS connections, domain routing, and certificate management.
Prerequisites¶
- Traefik v2.x installed and running
- Domain names configured to point to your server according to this guide
Overview¶
Traefik will handle all incoming web traffic and route appropriate requests to mailcow. This setup allows Traefik to:
- Manage SSL certificates
- Handle autodiscover and autoconfig services
- Handle frontend UI
- Pass ACME challenge responses for certificate validation of the mail server
Step 1: Update mailcow Configuration¶
First, modify your mailcow.conf
or .env
file to disable mailcow's built-in SSL handling:
# Disable mailcow autodiscover SAN
AUTODISCOVER_SAN=n
Step 2: Configure Traefik Dynamic Configuration¶
Create or update your Traefik dynamic configuration file with the following content:
http:
routers:
mailcow-acme:
entryPoints: web
rule: "(Host(`mx.domain.com`) && PathPrefix(`/.well-known/acme-challenge/`))" # "Host" should be equal to your `MAILCOW_HOSTNAME`
service: mailcow-acme
tls: false
mailcow-frontend:
entryPoints: "websecure"
rule: "Host(`mail.domain.com`)"
service: mailcow-frontend
tls:
certResolver: cloudflare
mailcow-autoconfig:
rule: "Host(`autoconfig.domain.com`)"
tls:
mailcow-autodiscover:
rule: "Host(`autodiscover.domain.com`)"
tls:
services:
mailcow-acme:
loadBalancer:
servers:
- url: "http://10.0.0.16:80" # mailcow local IP and web port
mailcow-frontend:
loadBalancer:
servers:
Important notes about this configuration:
- Replace
mx.domain.com
,mail.domain.com
,autoconfig.domain.com
, andautodiscover.domain.com
with your actual domain names - Update
10.0.0.16
with the actual IP address of your mailcow server entryPoints: "websecure"
- replace it with your actual Traefik https entrypointcertResolver: cloudflare
- replace it with your actual certificate resolver
Step 3: Restart Services¶
Restart both Traefik and mailcow to apply the changes:
# Restart mailcow
cd /path/to/mailcow-dockerized
docker compose up -d
# Restart mailcow
docker-compose up -d
Testing Your Configuration¶
- Visit
https://mail.domain.com
to check if the mailcow web interface loads properly - Configure an email client to test autodiscover functionality
- Monitor Traefik logs for any routing or certificate errors
Troubleshooting¶
Certificate Issues¶
- Check Traefik logs for certificate request failures
- Ensure DNS records are properly configured
- Check the logs of the
acme-mailcow
container
Routing Problems¶
- Verify network connectivity between Traefik and mailcow
- Check that the mailcow IP address is correct in Traefik configuration
- Make sure all required ports are open in firewalls
Service Access Issues¶
- Verify the
Host
rules match your actual domain names - Check that mailcow services are running and accessible on port 80 internally
