Nginx
Important
First read the overview.
Let's Encrypt will follow our rewrite, certificate requests will work fine.
Take care of highlighted lines.
server {
  listen 80 default_server;
  server_name CHANGE_TO_MAILCOW_HOSTNAME autodiscover.* autoconfig.*;
  return 301 https://$host$request_uri;
server {
  listen 443 ssl http2;
  listen [::]:443 ssl http2;
  ssl_certificate MAILCOW_PATH/data/assets/ssl/cert.pem;
  ssl_certificate_key MAILCOW_PATH/data/assets/ssl/key.pem;
  ssl_session_timeout 1d;
  ssl_session_tickets off;
  # See https://ssl-config.mozilla.org/#server=nginx for the latest ssl settings recommendations
  # An example config is given below
  ssl_protocols TLSv1.2;
  ssl_ciphers HIGH:!aNULL:!MD5:!SHA1:!kRSA;
  ssl_prefer_server_ciphers off;
  location /Microsoft-Server-ActiveSync {
    proxy_pass http://127.0.0.1:8080/Microsoft-Server-ActiveSync;
    proxy_connect_timeout 75;
    proxy_send_timeout 3650;
    proxy_read_timeout 3650;
    proxy_buffers 64 512k; # Needed since the 2022-04 Update for SOGo
    client_body_buffer_size 512k;
    client_max_body_size 0;
  location / {
    proxy_pass http://127.0.0.1:8080/;
  # The following Proxy Buffers has to be set if you want to use SOGo after the 2022-04 (April 2022) Update
  # Otherwise a Login will fail like this: https://github.com/mailcow/mailcow-dockerized/issues/4537
    proxy_buffer_size 128k;
    proxy_busy_buffers_size 512k;
When using a proxy on a different subnet you will need to add the following environment variable to the mailcow.conf to have the nginx container accept the X-Real-IP set above.
TRUSTED_PROXIES=#.#.#.#
