HAProxy (community supported)
Important
First read the overview.
Danger
This is an community supported contribution. Feel free to provide fixes.
This example redirects all HTTP traffic to HTTPS except for mailcow's built-in ACME client. If you do not want to use the built-in ACME client, please modify the configuration yourself.
frontend https-in
bind :::80 v4v6
bind :::443 v4v6 ssl crt mailcow.pem
acl mailcow_acme path -i -m beg /.well-known/
redirect scheme https code 301 if !{ ssl_fc } !mailcow_acme
default_backend mailcow
backend mailcow
option forwardfor
http-request set-header X-Forwarded-Proto https if { ssl_fc }
http-request set-header X-Forwarded-Proto http if !{ ssl_fc }
server mailcow 127.0.0.1:8080 check
