Apache 2.4
Important
First read the overview.
Required modules:
a2enmod rewrite proxy proxy_http headers ssl
Let's Encrypt will follow our rewrite, certificate requests in mailcow will work fine.
Take care of highlighted lines.
<VirtualHost *:80>
ServerName CHANGE_TO_MAILCOW_HOSTNAME
ServerAlias autodiscover.*
ServerAlias autoconfig.*
RewriteEngine on
RewriteCond %{HTTPS} off
RewriteRule ^/?(.*) https://%{HTTP_HOST}/$1 [R=301,L]
ProxyPass / http://127.0.0.1:8080/
ProxyPassReverse / http://127.0.0.1:8080/
ProxyPreserveHost On
ProxyAddHeaders On
RequestHeader set X-Forwarded-Proto "http"
</VirtualHost>
<VirtualHost *:443>
# You should proxy to a plain HTTP session to offload SSL processing
ProxyPass /Microsoft-Server-ActiveSync http://127.0.0.1:8080/Microsoft-Server-ActiveSync connectiontimeout=4000
ProxyPassReverse /Microsoft-Server-ActiveSync http://127.0.0.1:8080/Microsoft-Server-ActiveSync
ProxyAddHeaders On
RequestHeader set X-Forwarded-Proto "https"
SSLCertificateFile MAILCOW_PATH/data/assets/ssl/cert.pem
SSLCertificateKeyFile MAILCOW_PATH/data/assets/ssl/key.pem
# If you plan to proxy to a HTTPS host:
#SSLProxyEngine On
# If you plan to proxy to an untrusted HTTPS host:
#SSLProxyVerify none
#SSLProxyCheckPeerCN off
#SSLProxyCheckPeerName off
#SSLProxyCheckPeerExpire off
</VirtualHost>
