Generic-OIDC
Configure¶
To add or edit your Identity Provider configuration, log in to your mailcow UI as administrator, go to System > Configuration > Access > Identity Provider and select Generic-OIDC from the Identity Provider dropdown.
Authorization Endpoint: The provider's authorization server URL.Token Endpoint: The provider's token server URL.User Info Endpoint: The provider's user info server URL.Client ID: The Client ID assigned to mailcow Client in OIDC provider.Client Secret: The Client Secret assigned to the mailcow client in OIDC provider.Redirect URL: The redirect URL that OIDC provider will use after authentication. This should point to your mailcow UI. Example:https://mail.mailcow.tldClient Scopes: Specifies the OIDC scopes requested during authentication. The default scopes areopenid profile email mailcow_templateAttribute Mapping:Attribute: Defines the attribute value that should be mapped.Template: Specifies which mailbox template should be applied for the defined attribute value
Ignore SSL Errors: If enabled, SSL certificate validation is bypassed.
Automatic User Provisioning¶
If a user does not exist in mailcow and logs in via mailcow UI, the user will be automatically created, provided that a matching attribute mapping is configured.
How It Works¶
- On login, mailcow initializes an Authorization Code Flow and, if successful, retrieves the user's OIDC token.
- mailcow then looks for the
mailcow_templatevalue in the user info and retrieves it. - If the value matches an attribute defined in the Attribute Mapping, the corresponding mailbox template is applied.
Example Configuration¶
- The user has an attribute
mailcow_templatewith the valuedefault, which can be retrieved from the User Info Endpoint. - Under Attribute Mapping, set
Attributetodefaultand select an appropriate mailbox template.
Updates on Login¶
Each time a user logs in via mailcow UI, mailcow checks if the assigned template has changed. If so, it updates the mailbox settings accordingly.
Change the Authentication Source for Existing Users¶
Once you have configured an Generic-OIDC Identity Provider, you can change the authentication source for existing users from mailcow to Generic-OIDC.
- Navigate to
E-Mail > Configuration > Mailboxes. - Edit the user.
- From the Identity Provider dropdown, select Generic-OIDC.
- Save the changes.
Notice
The existing SQL password is not overwritten. If you switch the authentication source back to mailcow, the user will be able to log in with their previous password.
Authentication for External Mail Clients (IMAP, SIEVE, POP3, SMTP)¶
Before users can use external mail clients, they must first log in to the mailcow UI and navigate to the Mailbox Settings.
In the App Passwords tab, they can generate a new app password, which must then be used for authentication in the external mail client.
Troubleshooting¶
If users are unable to log in, follow these steps to diagnose and resolve the issue:
Test Connection
- Navigate to
System > Configuration > Access > Identity Provider. - Run the Connection Test and ensure it completes successfully.
- Navigate to
Verfiy Client details
- Navigate to
System > Configuration > Access > Identity Provider. - verify that Client ID and Client Secret matches data of OIDC Provider
- Navigate to
Verify the User’s Mail Domain
- Ensure the user’s mail domain exists in mailcow.
- Check if the domain is limited by "Max. possible mailboxes" or "Domain quota".
Confirm Attribute Mapping
- Make sure a matching Attribute Mapping is configured for the users.
